PSE Amber Essex LED Dual-Head, Rear Deck-Mount Light, Red
We compared price of PSE Amber Essex LED Dual-Head, Rear Deck-Mount Light, Red across hundreds of online stores. We found PSE Amber Essex LED Dual-Head, Rear Deck-Mount Light, Red in 1 store with lowest price $140.00 in AW Direct. For detailed price comparison of PSE Amber Essex LED Dual-Head, Rear Deck-Mount Light, Red check table below.
Merchant | Price | - |
AW Direct | [show price] |
PSE Amber Essex LED Dual-Head, Rear Deck-Mount Light, Red description from AW Direct
53 User selectable dual head flash patterns 12 VDC 7W X 2H x 2-1/2W Compact Essex-Dual Head Light provides plenty of bright light and easily fits on the rear deck. Flared visor for a much greater off-angle light signal. Clear lens with red LEDs.
Customer review
I am very blissful with purchase of PSE AMBER additional and the marketer . speedy transportation and goodness communicating.
