Safco 10 Drawer Metal Flat Files Cabinet for 30 x 42 Documents in Tropic Sand
main picture
We compared price of Safco 10 Drawer Metal Flat Files Cabinet for 30 x 42 Documents in Tropic Sand across hundreds of online stores. We found Safco 10 Drawer Metal Flat Files Cabinet for 30 x 42 Documents in Tropic Sand in 1 store with lowest price $2939.98 in Cymax. For detailed price comparison of Safco 10 Drawer Metal Flat Files Cabinet for 30 x 42 Documents in Tropic Sand check table below.
Merchant Price -
Cymax [show price]
Safco 10 Drawer Metal Flat Files Cabinet for 30 x 42 Documents in Tropic Sand description from Cymax
Safco - Flat Files - 4986TS - This 10-Drawer Flat File Cabinet is all business and is a space-saving means of office filing all 30 x 42 documents. This cabinet's files are modular, so they can be used individually or in a space-saving stack, and case-hardened ball-bearing rollers provide you with smooth, quiet operation. Positive closures keep your drawers tightly shut, while courtesy stops keep them in place while open. Keep contents clean with a rear hood and hinged front depressor. Weight Capacity: 50 lbs per drawer ; Accommodates 30 x 42 Documents ; Material (s) : Steel ; Finish: tropic sand ; Material Thickness: 22 ga. (cabinet) ; Stackable: 2 units on a closed base; 1 unit on a high base ; Sheet Capacity: 300 - Active; 450 - Semi Active; 600 - In Active ; Recycled: Meets or exceeds 25%, 0% post consumer ; Depth of File: 35 3/8 without handles ; Fits Sheet Size: 43 x 32, 30 x 42 ; GREENGUARD approved* ; Lockable: No ; Assembly Required . Specifications: Drawer Dimensions: 43w x 32d x 1 1/4h ; Overall Dimensions: 46 3/8w x 35 3/8d x 16 1/2h ; Weight: 278 lbs. * As an industry leader, Safco aims to set high environmental standards offering a large collection of GREENGUARD Indoor Air Quality Certified products and GREENGUARD Children and Schools Certified products. The GREENGUARD Certification Program is internationally recognized for evaluating product emissions and certifying building materials, furnishings, finishes, and cleaning products and processes that meet stringent indoor air quality criteria defined by GEI.
Customer review
If you want really good storage cabinets, you can try this Safco 10 Drawer Metal Flat Files Cabinet for 30 x 42 Documents in Tropic Sand. It's unbelievable!
